Cygnus & Coathanger w/Home Depot timer & Canon A53
Started by Exosearch, 06/15/2008 06:55PM
Posted 06/15/2008 06:55PM Opening Post
Stars in Cygnus (make sure to expand to full size in your browser to see the Coathanger, upside-down.)
http://setisociety.org/Cygnus-via-CanonA530.jpg
Camera only mounted on a Home Depot mechanical timer. The stack is 4 frames of 15 second exposures from a Canon A530 point-n-shoot camera.) I was able to make and attach a very light mounting fixture from PVC, aluminum and stainless steel bolts which permits a more secure and greater degree of motion for camera pointing (by itself it's not pointable to all parts of the sky, however I think that by using this in combination with a gorilla-pod one should be able to do a whole sky mosaic with only parts from a home supply store [beware to not touch the live electrical wires within the timer!!!] and a department store camera.)
Here are shots of the setup:
http://setisociety.org/IMG_1145.JPG
http://setisociety.org/IMG_1146.JPG
http://setisociety.org/IMG_1147.JPG
http://setisociety.org/IMG_1148.JPG
http://setisociety.org/IMG_1149.JPG
http://setisociety.org/IMG_1150.JPG
Where the wing-nut is is where the camera goes (it's a quarter-20
screw). You can see the differences in positions between each frame
of the head. If I want to go near Polaris, it's necessary to use a
gorilla-pod (see google images "gorrilla pod".)
Regards, Jason H.
Posted 06/16/2008 02:39AM | Edited 06/16/2008 02:51AM #1
Although not as big as the first one I posted on this thread, I re-processed the same 4 frame stack in an attempt to bring out the Milky Way dust/star clouds that seemed hinted at in the original
http://setisociety.org/Cygnus4frameDust.jpg
Downscaling seemed to help bring that out too.
Jason H.
Exosearch's attachment for post 123034
