Shane Yarnall
LDN 1622
Drift EW - 6543
Started by hakescl, 06/09/2009 04:46AM
Posted 06/09/2009 04:46AM | Edited 06/09/2009 09:50PM Opening Post
This one is the Cat's Eye. Taken last night with the full moon. It was just over 90 degrees from the moon, so there shouldn't have been any direct light going in, but it was REALLY bright out there. 6nm Ha filter and 6 minute subs. (Rats - Turns out the core is still saturated.) Again, no declination guiding and good tracking by the end of the E-W tweaks on the wedge. There are 12 subs, and the flat was that of the luminance filter - wrong one, but that is what there was. Might be worth figuring out how to combine different exposures, since I think I could go much longer than 6 minutes now to get that outside part. Lots of smoothing in the dark areas.
Charlie
hakescl's attachment for post 47129
Darkness - typically 6.5+
Focus - JMI Smart focus
Posted 06/09/2009 08:40PM #1
nice... this one would be easy to layer in short exp. given the sharp transition. You've got the hard part done!
mike
Posted 06/10/2009 12:34PM #2
Neat object!
Looks like you have your alignment dialed in well. I've shot some subs on M57 that looked pretty well saturated,it's a bright little sucker! I went real easy with the stretching to keep it from blowing out the highlights.
Jason
Posted 06/11/2009 10:33PM #3
Nice capture Charlie. Like Mike says, the hard part is done if you want to go back and get some shorter subs.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
