Ghost of Cassiopeia
First test of the Astrodon Gen 2 RGBL filters.
Started by fblue, 01/17/2009 08:08PM
Posted 01/17/2009 08:08PM Opening Post
Last night I went to a local site to do some testing of the new filters as well as the new MClennan Gearbox that I had installed on the G-11. I will not get into the mount tests, they are found in the Mount and Losmandy forums here.
But the filters I will discuss a little.
I have used Meade and Astronomik RGBL filters in the past and had read about and seen the results of the new Gen 2 filters and their suppression of internal reflections on bright stars. Some before and after shots with the Gen 1 and Gen 2 filters that people showed me were impressive.
So I decided to buy the filters and see for myself, whether there was a big improvement.
My shots of M45 and The Horse Head were plagued with reflections of Alnitak and the bright stars of M45 in the nebula. So I went out last night and did some test images of both these objects as well as Sirius and Betelgeuse to check for reflections. There were no reflections at all with 10 minute exposures. I did have a misalignment issue that was the camera in the focuser, but later I found that and then there were no aberrations or reflections at all. The filters showed nothing but the stars!
So, these filters do indeed eliminate the reflections that are so common on these type objects and situations. The cost is greater, $450 for the set compared to $279 for the Astronomik set, but if you can afford the difference, you will see the difference.
I am pleased with the filters and look forward to more exposures with them. grin
