Am I the only one in the world who has trouble with field flatteners/fpocal reducers on an SCT?
After having a few otherwise great shots ruined by lens flare while using a standard 6.3 compressor/field flattener on my C9.25, I decided to run a test. I borrowed three field such things from my friends (three Celestron, one Meade). I stuck them in the tube, pointed at the Pleiades, and got the following, from all four of them. And I often get this kind of thing when using a flattener. It appears to come from stars just outside the FOV, although I don't know if that is true. I have done all the obvious (looking down the barrel for anything shiny, etc.)
Oh, I should add that I do not notice it when using the scope at F10 (without flattener/reducer).
What is your experience? Is this a common problem. Is there a trick to using the field flattener/Corrector/Focal reducer that overcomes this?
