Shane Yarnall
LDN 1622
Focusing aids
Started by fblue, 08/31/2007 07:05PM
Posted 08/31/2007 07:05PM Opening Post
I have been experimenting for a few weeks now with different focusing aids, masks.
So far I have tried four different types of masks.
1) Standard 3 hole Hartman Mask
2) Triangle 3 hole Hartman Mask with offset triangles.
3) 3 hole Hartman mask with two round and one triangle hole.
4) crossed hair type mask using different thickness crossed hairs
See picture that shows 3 of these type, with the 3 hole Hartman modified to have one triangle and two round holes.
Each of these masks seems to have a good side to them. But certain ones seem to be much easier to judge the focus. These are the crossed hair type. I then decided to try different thickness of crossed hairs ranging from thread to 1/2" strips of ABS.
What I have found so far is this.
The thin hair shows a thin long spike arrangement that is pretty easy to see and judge.
The very wide 1/2" is ok, but does seem somewhat harder to judge.
The medium thick, in this case coat hanger wire hairs seem the best overall.
The 1 triangle and 2 round holes is next in line for ease of focus.
The 3 round hole mask to me is the hardest to judge.
The coat hanger size hair does something unusual, I guess due to the round wire and thickness. Where the hairs cross the star creates a bright cross as it gets close to focus, then just outside of this cross, a single almost diamond shape appears in the spike. It gets brighter as focus is closest and dims as you pass prime focus. It makes the reading of the spikes a bit simpler as there is less distraction with trying to judge the entire spike as a whole. Not sure whether this is a fluke in my design and materials, but it certainly is a good thing.
I will next post a picture of the coat hanger wire mask for reference. It was made from a small plastic pot for plants that you get at Lowes.
fblue's attachment for post 38470
Posted 08/31/2007 07:13PM | Edited 08/31/2007 07:15PM #1
Ok, here is the crossed hair mask made with coat hangar wire and a plant pot. It fits the 80mm quite well and all that is needed is a pot that will slip inside your dew shield.
Cost is near nothing if you have a pot and don't have to buy a plant to get one! wink You can also buy the pots very cheaply.
Cut the bottom off the pot. Just make 4 holes the size of the coat hangar, if you are luck as I was the pot has tic marks around the inside to guide you in making the holes, cut the wire and bend the end over 90° and slide into place, then bend that end over. Repeat for second wire and paint flat black on the inside and gloss on the outside if you have it, gloss takes the sliding in and out better, and you have a dandy focusing aid.
fblue's attachment for post 116519
