Ha RGB images are always an interesting process adventure....
In this case, I started off with my RGB data straight up, strongly stretched as a color layer, Ha as luminance (layered a few times). The final result was color balanced (blue and green reduction) in the mid-reds to achieve roughly a 3:1:1 / R:G:B ratio (a step I sometimes take to minimize salmon or pink). All done with a star mask. So in other words, no direct mix of Ha into R or B.
Image is here:
http://www.jthommes.com/Astro/IC1805.htm
(click on the image for higher resolution)
Scope - WO Zenithstar 66 mm APO
Camera - ST8300M (Astronomik Ha RGB filters)
Mount - G11/Gemini
Guiding - WO Megrez 80 mm at 555 mm FL, DSI Pro, PhD Guiding
Image is here:
Mount - G11/Gemini
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
