I still consider this a work in progress.....
Here's a 2-hour H-alpha of the Horsehead region. It's probably not obvious unless you blow it up (way up!), but there's some field curvature visible in the stars towards the corners - the reducer I'm using is likely not at its optimal distance, but this is not my long-term configuration anyhow...
Takahashi FS102 with f/5.9 reducer
SBIG STL-6303
Astrodon 6nm H-alpha filter
4 x 30 minute subs
Reduced in size by about 1/3
I stretched it a bit to show that the nebulosity that's not usually obvious below the HH region is beginning to show up. But that's for another time....
Eric
SBIG STL-6303
4 x 30 minute subs
Eric
