The MN66 came in today and I spent all afternoon finishing the Saddle Plate for it and making the guide scope plate fit the plate on the rings.
Everything appears to be going great. The weight and balance is good, balanced about the middle of the OTA and total weight with guide scope, rings and plates and dew shield is 29 lbs. With cameras that should put it at maybe 31-32 lbs. Well within the limits of the G-11.
The JMI Motofocus that I use on the WO 80mm and the Meade 127ED also fits the MN66 focuser, so I have a working electric focuser!
Tomorrow I will set up the G-11 and put everything together and see how the balance is mounted and how much counter weight I will need to use.
The G-11 has the new Ovision RA Worm and Block installed and adjusted. This should help with the additional weight of the new scope.
Hopefully I will get my first image the week before New Moon, when conditions are better.
