Moonlight focuser and GSO 8" f/4. Backfocus problem??!?
Started by moutinho, 05/11/2008 03:55AM
Posted 05/11/2008 03:55AM | Edited 05/11/2008 03:56AM Opening Post
Hello,
I want to replace the stock GSO 8" f/4 focuser with the Moonlight CR2.
I intend to use this setup with the Baader MPCC and a DSLR 350D camera.
Does anyone here know if I will have back focus problem?
Thanks
Andre
Posted 05/11/2008 01:54PM #1
Andre,
You may have an issue with reaching focus. Try to get as low a profile focuser as you can. I had an issue with a GSO 8"f/4. I replaced the stock focuser with the low profile focuser from GSO. Even with this modification, the Digital Rebel would come to focus with the Baader MPCC screwed into the T-adapter with only two mm of inwards travel left. If I used an Antares 2" prime focus adapter, it wouldn't come to focus at all. You should think about getting as low a profile focuser as you can and also get GSO's own 2" prime focus adapter tube (Orion now sells a comparable one) if you plan to image without an MPCC.
Anjal.
