RICHARD COFER
More M16 data
Started by hakescl, 09/27/2008 07:48PM
Posted 09/27/2008 07:48PM Opening Post
I finally have a "full set" of colors to play with on M16 - IR, SII, Ha and OIII. I still need more of each, and so far I have not taken any Luminance data, but now I can mix and match to see which direction I should try to head with the processing. This is 57, 30, and 60 minutes each in 3 minute subs. So I made a first cut at loading into Astroart and seeing what the "auto-range" spits out. I stretched the "log" button as far as it would go, but no other processing here.
Obviously (?) some mixes are more pleasing than others, so your input would be most welcome. This first one is the Hubble Palette of SI,Ha,OIII. (I will have to try and get rid of the pink halos on the next iteration.)
clear skies,
Charlie
hakescl's attachment for post 43922
Darkness - typically 6.5+
Focus - JMI Smart focus
Posted 09/27/2008 07:56PM #1
And here is the Ha-SII-OIII mix if you would rather have blue halos.
hakescl's attachment for post 125231
