OK-its Minnesota and its cold. At 7pm local time yesterday, the temp is -23F at the observatory. In the "Old Days" there is no way I would even think of trying to get a film image with these conditions. But that was then.... Opened up the roof and turned on the equipment (MI-250 carrying a C11) somewhat reluctantly. As anyone who has experienced these temps knows, equipment makes funny sounds when it fires up and you don't know if that's normal under those conditions. Fan on the ST8 sounded louder than normal, slewing motors were definitely louder but no stalls or tracking issues. Proceeded to take the attached image of NGC 1514. Used an ST8-XME with an AO8 and the guide star exposure was only .1 of a second. Stars were bouncing all around but the AO8 still returned round stars so that works under those conditions. Only thing that didn't work like it should have was the Gemini unit when it first powered up-did a CMOS reset even though it was a fresh battery in November (I don't think batteries are supposed to be stored and used at these temps and still be reliable). Chip temp was -40C and the percent used was only 9%! Just for fun, I wanted to see how low I could get the temp so I dropped the chip temp to -78C and that was at 87% capacity.
Image processed only in CCDSoft using Add combine.
Going out tonight because its warm at +1F! Almost 25 degrees warmer than last night!
