ngc 2392 - 9" tmb and 2+ barlow...
Started by stargazer_7000, 01/09/2008 10:17PM
Posted 01/09/2008 10:17PM | Edited 01/09/2008 10:19PM Opening Post
hi gang,
hey - what is that? luminance only...? no color...?
well,
this is a result of an experiment I conducted last night when seeing was really very good for a short periode.
I used a monochromatic demo-CCD SXVF H36, my 9" TMB apo but this time @ f/18 !
I slammed in the 2" 2* big barlow cos I wanted to see, if the system is powerful enough to allow imaging bright small planetary nebulas - which shall become one of my future tasks,...I hope.
singel frames were only 4 minutes 'short' and it worked nicely.
I also took rgb files, but in primary focus at f/9.
today when preprocessing the data the bad news came along:
after completing luminance and r,g,b seperatly I wanted to registar and align these 2 master-frames.
but - no chance to do so! no software I used was able to stack these two successfully!
I really did not expect this in the fist place.
I often use f/9 data and combine it with f/7 data, when I use my reducer/flattener.
but obviously there is a big difference in what happens to the field when trying to combine f/9 and f/18...
I would have had to crop the image so dramatically that I refused to do so,...cos it would have been to embarrassing...
frankly, this luminance image you see in the full size is already a crop, as my f/9 system illuminantes the chip nicely, but fails to cast nice round stars onto the chip all over the area.
I had to crop the frames down to 50% !
so - I N E E D a decent flattener for my 9" TMB Apo f/9.
in future I'll have to do my r,g,b files also with the barlow lenses...
data:
8.1.08:
9" f/18 (TV 2" 2* big barlow)
SXVF H36 (50% crop)
18x4 minutes single frams
7 darkframes
image acquisition: AA4
preprocessing (dark-calibration, kernel filtering, alignment, stacking and Deconv. in maxim dl)
pre-sharpening in CCD sharp. DDP in Maxim DL.
postprocessing in PS CS2.
full size (crop) can be found here:
http://www.stargazer-observatory.com/2392-full-L.html
an enlarged crop is here:
http://www.stargazer-observatory.com/2392-enl-crop-L.html
clear skies, guys!
Dietmar
Posted 01/09/2008 10:25PM #1
dietmar hager said:
........no software I used was able to stack these two successfully! ............
Did you try Registar?
It's about the best when it comes to combining different image scales.
dan
Posted 01/10/2008 05:40AM #2
Dietmar,
Wow, 9" TMB at f18! Very sharp and clear.
Can't wait to see you add the color.
Phil
Posted 01/10/2008 05:49AM #3
Dietmar,
I love the detail you were able to get on this guy. It's really pretty amazing.
Too bad about the RGBs though. I guess if you really wanted to kill some time. you could try various distortions and free transforms in PS to try to get the curvature to match up.
I liked your M76 a lot as well. Looks like you arereally movinginto the small image scale objects - and doing a great job with them.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
Posted 01/10/2008 04:44PM #4
Diets,
Very nice job on this! Why not crop the RGB and Luminance severely enough that you can get them to align? I wouldn't mind seeing just the nebula in LRGB wink
Eric
