Iris Nebula
Picture of the TEC Flattener and AP Reducer
Started by fblue, 12/26/2010 08:33PM
Posted 12/26/2010 08:33PM Opening Post
Here is a picture of both units. The TEC 140 Flattener is on the left and the AP Reducer is on the right.
You can see how much larger the TEC Flattener is, with an 88mm lens.
I will use each for the FOV and focal ratio it provides. The Flattener will give f/7 and the Reducer gives f/5.6.
fblue's attachment for post 52500
Posted 12/27/2010 04:01PM | Edited 12/27/2010 04:07PM #1
Hi Floyd:
I don't think that it matters at all in a practical sense, but the TEC flattener actually gives an f ratio of about 7.25. In other words the focal length of the system goes from 980 to about 1015 mm with the flattener installed. (According to my plate solves) The only situation I can think of where this info might matter would be if one were planning a mosaic with a very specific and tight overlap area.
I'm sure you've tested yours by now, but for those who might not know, the TEC flattener produces an exceptionally flat field. (The attached is the entire un-cropped surface of a 35mm chip.)
Jim
jameslbrown's attachment for post 139386
Posted 12/27/2010 06:00PM #2
It looks like you are comparing Yuri's FF with the smaller offering from AP. The TEC FF is designed to be usable with medium format cameras (85 mm spacing). The 2.7" AP reducer doesn't try that hard, but they also have 4" corrector/reducers that will cover larger areas.
Jim McSheehy
