I have access to an LXD-55 (similar) mount that I am in the process of setting up to take widefield shots. I have had some success with really wide DSLR views when I could get it really lined up with the pole. However, the biggest issue is that it does not have a standard autoguiding port. I recently purchased a "909 clone" of a Meade adapter that is no longer made that should allow guiding. Unfortunately I have not had a chance to complete testing of this via a GPUSB adapter. Definitely not the most straightforward setup I have ever seen. If it turns out autoguiding does work, then I will be able to test with a pair of 80mm scopes - one to guide and one to image. And will certainly report on what I find. Although this mount came with a Meade 5" refractor, it feels minimal for even the smaller scopes for imaging. Your 130mm sure sounds big.
Here is an example with a 110mm fl camera lens. I thought the tracking was great (for no guiding) this time, but you can still tell the stars got streaked.
http://www.fortlewis.edu/observatory/image_detail.asp?ID=179
Charlie
Charlie
Darkness - typically 6.5+
Focus - JMI Smart focus
