I start from the fact that this image should not be here, hmmm .. should not arise. It should not be here because it is poor quality and should not arise because I knew that I tow with a hoe on the Sun.
Well, but first it is a beautiful pair of nebulae, second - I've made with it and, third, .. may be a warning to colleagues that it is reasonable to precisely select objects.
Unfortunately, I change the setup and I have yet to finish the chances of this photo, maybe for a year. This is the darkest objects that I have tried so far to photograph.
So: two supernovae remnants in Auriga SH2-224 Rice Hat Nebula and round SH2-223. The brightest star in this picture Rho Aurigae is about 5.2 ( it is artificially reduced - the halo took fourth of the screen)
On one hand you can count the pictures of these objects available on the net.
Setup: FSQ 106N F / 5, STL11000, Takahashi EM-11.
Ha: L: R: G: B - 24 H x 1 x 1 x 1 x 1 November 2011-January 2012.
Ha is a 32 x 45 minutes. Increasing the number of shots is not probably make sense. This is not an object of this setup.
Look here: http://img513.imageshack.us/img513/7933/finalxbf.jpg
