I have an Explore Scientific 80mm apo, with which a Vixen NLVW 30mm eyepiece will not reach focus with the diagonal attached. It seems the tube should be shortened, so I seek advice on how much to shorten for convenient imaging.
The OTA has a 480mm focal length. The very well made dual speed focuser has a draw of 100mm. By holding the tube in the direction of the setting sun, I found that the focal point appears to be almost exactly at the end of the extended drawtube. This seems a mistake, as there is no useful optical device that would need a focus at the actual end of the drawtube.
Furthermore, with the 2" diagonal, all my eyepieces come to focus very near the in travel limit: a 42mm Plossl focuses at 30mm extension, while the older Vixen LVW types focus at 10mm. The NLVW, comes almost to focus at the inward limit of the focuser.
So, I could have it shortened. How much should it be shortened for optimal use as an astrophotography instrument?
