I'd like some opinions from experienced CCD users on whether a STL11000CM is an upgrade over a ST2000XM with a filter wheel.
I notice with some images using a filter wheel you're polar alignment has to be spot on as well as you probably need to refocus with each new filter.
Otherwise you can get rotational effects and bloating effects that reduce the sharpness and resolution of the image. As well as cause some colour artifacts.
Ideally, the images is shot with the same conditions each time. That would mean ideally all colours shot at the same time under the same conditions for that period of exposure. Things rarely duplicate accurately unless a lot fo care is taken (which is OK too but more work and less images will wind up acceptable for use but would ultimately be a higher quality).
I think this is one of the best cases for one shot colour cameras. All colours are shot under the exact same circumstances without minor changes entering in.
For example, you shoot LRG and ready for blue. Cloud comes in! OK. That session is wasted until you can shoot blue another night and spend a fair while aligning before shooting the image. You may also end up compromising on autoguider exposure length to make sure it will be bright enough when the blue filter has its turn.
Comments?
Greg.
Comments?
Greg.
