I have been looking at two scopes for imaging as a longer f/l to compliment my NP101.
The NP101 works great for wide field images, but I would like to have something that imaged at a higher res, image scale, and larger aperture to make that work better.
Looking at two alternatives;
1) 7.1" Mak/Cass f/6 which has high quality optics and designed as an Astrograph. This would give a flat, well corrected field, with a 1.4" image scale and 1080mm f/l. Well built unit with a fine ring set that would accept a guide scope and dove tail plate and a good finder scope. Cost $3250
2) 8" RC f/8 with optics that are Guan Sheng and certainly not as good as the Mak/Cass from what can be seen in optical tests done by Wolfgang.
Flat well corrected field with .95" image scale and 1600mm f/l. Comes with a Dovetail Plate but no rings for the guide scope or any method for attachment of one. But could probably come up with a solution. Has no finder, but a finder shoe is included. Two speed focuser, Crayford style, typical Chinese type. Cost $1400
Each of these scopes has its pluses and minuses and of course a huge cost difference. But, the real questions I have are,
1) Which would be the better Astrograph and produce the better images?
2) Would the larger aperture make up for the slower focal ratio and lessor optics?
3) Or would the smaller aperture with faster focal ratio and better optics prevail?
I would like your opinions on these and any other information you would like to add would also be appreciated.
