Advice needed: Afocal vs Eyepiece Projection
Started by ivanong, 03/07/2004 02:32PM
Posted 03/07/2004 02:32PM Opening Post
Hi All, need your opinion/advice on the following:
I have my C9.25" scope set up to do both of the following:
(a) Afocal via my small Nikon 4300 using ScopeTronix's adapters and (b) Eyepiece projection using Celestron's "deluxe" Teleextender with my digital Rebel.
Problem:
I have found that the Afocal technique consistently gives better images and is much easier to focus. The EP projection yields very soft digital images and is incredibly hard to focus. EP projection images taken so far are pretty useless for processing.
Am I missing something here or is this the general case?
Thanks in advance,
Ivan
Posted 03/07/2004 04:09PM #1
Most of the images posted on these forums that were taken with the digital rebel were done at prime focus rather than with eyepiece projection. With a C9.25, the Digital rebel will yield a 33 arcminute by 22 arcminute field, which is pretty small. Depending on how you have the tele-extender set up, you are probably using at least 3 or 4 times that magnification, which will make the image impossible to focus through the viewfinder. I would just attach the Digital rebel the same way you would attach a 35mm SLR, it may even be a good idea to try a .63x reducer if you have one. The pixel sixe of the Digital Rebel is pretty tiny and will probably record about as much detail as you can get without any additional magnification.
Joplin
