Aug. 3rd pm Jupiter 6" afocal experiment
Started by Exosearch, 08/04/2008 07:18AM
Posted 08/04/2008 07:18AM | Edited 08/04/2008 09:12AM Opening Post
Jupiter
http://setisociety.org/jupiterMVI_1218regonepointfiverox.jpg
Just reporting on tonight's experiment. Even though I speculate that the Canon Powershot A530 already has an IR blocking filter, I decided to try an additional Lumicon IR blocking filter (in case it has a slightly different spectral response.) I don't see an improvement, but I also was messing with other things too so the verdict is still out on that one. This time I used the new Parks 7.5 mm Gold Series with a Japan made 2x Celestron Ultima barlow in the Criterion RV-6 (a 6" newtonian) and it was way way overkill on magnification when combined with the 7.5, so much so that it left me with poor quality videos (even though the seeing was good) and only permitted me to stack a small amount of frames. Also, Registax didn't seem to like the larger scale objects in the videos and actually lost the tracking on some of them (it hasn't done that in awhile.) I basically have to decide whether it's worth using the barlow, because the overmagnification is causing too much darkness (but I'll also have to try it without the IR filter). I didn't adjust the exposure on purpose) and here in this dark room I can see Io to the left, but I'm guessing when you read this it will be difficult to see Jupiter in a well lit room (let alone Io), however whenever I tried to adjust the exposure, it just made Jupiter look very un-natural, so I just left it alone to show what happened and reduced the overall size to 75% of the original.
Regards, Jason H.
Exosearch's attachment for post 43128
Posted 08/04/2008 11:36AM #1
That is darned good image for a 6" scope! I hope you don't mind, but I took liberties with the image and adjusted levels, saturation, and contrast with PS...Io is still tough to see, but you got a lot of detail on Jupiter.
Steve
Steve OK's attachment for post 124039
Posted 09/03/2008 07:48AM #2
Awhile back I had posted a shot from an Aug. 3rd experiment (that subsequently looked pretty lame because of some other posts here from smaller scopes, but it was a happy experiment), and the following shot is from the very next video run in the 6" Criterion, but I processed it somewhat differently.
http://setisociety.org/JUPITER-1219-GOINGALLTHEWAY-1007.jpg
I guess it's heavy handed, but I think it came out better than the other one from that night.
Jason H.
Jason Higley said:
Jupiter
Regards, Jason H.
Exosearch's attachment for post 124690
