Mark Eby
M33 Triangulum Galaxy
Endymion, Humboldtianum, Marginis etc.
Started by stefan lammel, 06/02/2009 04:10AM
Posted 06/02/2009 04:10AM Opening Post
Hi all,
I managed to squeeze in a session on Saturday, probably the last this year until
the Moon gets a bit higher again in September. These images were taken as the
sun was setting so the AVIs were bright from sky glow and needed quite a bit of
stretching which resulted in even more noise than usual (next time maybe I
should try 12 bit capture to hopefully cope better with the effects of the extra
stretching).
Again I used the new generation Baader blue filter, I thought I would probably
need to change it due to the Moon's low altitude at around 30-35 degrees but it
was ok and I was again pleasantly surprised by the results. The Moon was down to
29 degrees by the end of the AVI covering the right hand side of the Marginis
image but I think the result was still worthwhile.
Hercules, Atlas, Endymion & Mare Humboldtianum
http://www.pbase.com/slammel/image/113222533/original
http://www.pbase.com/slammel/image/113222492/original (x1.2)
Notice the concentric crater just below Endymion.
Maria Marginis, Smythii, Undarum & Spumans
http://upload.pbase.com/image/113165859/original
http://upload.pbase.com/image/113166514/original (x1.15)
You can just about make out the swirls in Marginis, although under this lighting
and resolution everything is a bit swirly ;o) The x1.15 enlargement is noisy and
probably a bit pointless but might work for some, it looks ok on my blurry old
crt but not so good on the laptop.
(BTW, for those using Firefox there is a nice 'hand' tool add-on that makes
navigating large images much easier
https://addons.mozilla.org/en-US/firefox/addon/1250 . Apart from moving the
image around, with the flick gesture you can get the image moving slowly across
the screen like a 'fly over' effect, well it's cheaper than the real thing
anyway! ;o)
10in f4.8 Newtonian, Infinity 2-1M, 5x Powermate, blue filter, Avistack,
Registax 5, PSE5, Focus Magic
Regards,
Stefan
stefan lammel's attachment for post 47060
[COLOR="Navy"]
Stefan Lammel
[SIZE="Small"]
http://www.pbase.com/slammel/moon [/COLOR][/SIZE]
Posted 06/04/2009 03:42PM #1
As usual your images are breathtaking Stefan 8O
You are truly one of the masters of lunar imaging: congratulations!
Thanks for posting them
Luca
www.amun-ra.org
Solar Imaging Website
