Image scale and target surface?
Started by Astrovale, 12/26/2007 05:15PM
Posted 12/26/2007 05:15PM | Edited 12/26/2007 05:28PM Opening Post
Hello guys,
I know it must be a matter of simple mathematics, and so this is ultimately a dumb question, but I can't get it cwy
How do I translate my image scale in area covered on the target?
I mean this: if I image an object at distance d at 1 arcsec/pixel, how many square meters on the object's surface does a pixel cover? Is there a simple formula that ties these quantities (image scale; distance; target surface)?
The area covered must be directly proportional to the distance d, but that's about as far as I can get. I also thought it could be approximated to calculating the base of an isosceles triangle with height equal to the target distance d and vertex angle equal to, in our example, 1 arcsec (the other 2 being then 1/2*(180°- known angle)). Unfortunately, I don't know how to calculate the length of a triangle's sides knowing its angles. If I could find the length of the long side, I could Pythagoras to calculate the short side and with it the area covered by one pixel and by my whole sensor.
I often wonder how much solar or lunar surface is pictured in my images and, with such a formula handy I would know at once grin
Sorry about the long post guys and thanks for any help you can give!
Luca
www.amun-ra.org
Solar Imaging Website
Posted 12/26/2007 08:08PM | Edited 12/26/2007 08:19PM #1
The size of your 1 arcsecond pixel at the target is
approximately d / 206000, where d is the distance to
the target.
It is basically a very long skinny isosceles triangle.
If the angle is 1 arcseconds, the ratio of the long
sides to the small side is about 20600.
An exact calculation using trigonometry is
target = 2 d (tan(angle/2))
For small angles with the angle measured in radians one can approximate
tan(angle/2)=angle/2
so you have
target = 2 d (angle/2) = d * angle = d / 20600
where one arcsecond is pi / (180 * 60 * 60) radians
or about 20600.
