Wizard Nebula
imaging Jupiter w/ CDK 20 and dsi III ?
Started by astrogeek, 10/13/2010 04:58AM
Posted 10/13/2010 04:58AM Opening Post
I was wondering if I could get some pointers on imaging. The planet in question, Jupiter. The camera is a Meade DSI III at prime focus. The Telescope a CDK 20". Is it important to increase the f ratio to around 20 or so with a barlow or maybe eyepiece projection? Please steer me to a post, or link that I could find more information or examples (pictures) of successful attempts. Or would you recommend using a Toucam for planetary imaging in place of the Meade? Thanks
Posted 10/13/2010 05:32PM | Edited 10/13/2010 05:32PM #1
Not familiar with the Meade DS III. The key to sharp
planet imaging is a high frame rate -- like 20, 30,
maybe even 60 frames per second to freeze-out the image
motion. Check whether the DS III can do that (probably
not). Otherwise ToUcam would be much better choice.
The F-ratio will probably be determined by fiting all
the planet on the chip. You probably won't want to go
more than about F/20 with the ToUcam and a 20" scope.
The field-of-view with the ToUcam at F/20 is about 55
arcseconds.
Posted 10/14/2010 04:05PM #2
Mark,
If you can afford a CDK 20 then you don't want to mess around with a $100 web camera for planetary imaging. The Toucam can only do 15fps without introducing noise into the image stream.
There are better cameras in the $600 and up range that can do 60fps without noise. Look at Dragonfly, DMK, etc to get better quality.
Of course seeing conditions and good transparency are also a must but I presume you're in a location that has those if you have a 20 inch scope.
Weiman
