Is the Losmandy G11 mount relatively portable or I
Started by moutinho, 12/05/2004 01:48PM
Posted 12/05/2004 01:48PM Opening Post
Hi,
Is the Losmandy G11 mount relatively portable or I must have an observatory.
Andre
Posted 12/05/2004 01:57PM #1
Portable--as much as any operation that large can be considered portable.
Much easier than setting up a large fork mounted equatorial on a wedge. And much easier polar aligning when moved.
Mine breaks into one toolbox to hold the weights, one suitcase (size of a roll-on airline bag) to hold the head and related electronics, and a medium sized Rubbermaid trunk for the legs. Then the top of the Tripod comes along without a case. The head is the heaviest of these things, but still not too bad.
Posted 12/06/2004 11:21PM #2
Are you going to be moving it from inside the house to outside the house, or are you going to be moving it by car?I leave my tripod setup inside the house in a spare bedroom with one leg loose and the other two legs tight. I also have the gem resting on top of the tripod. I have the scope (a C11)on the floor sitting next to it with a TV-85 piggypacked on the scope. I have my eyepieces in one case, and power supply, level, screws and everything else I need in another case. I leave the weights in my truck, since I setup in my driveway. When it is time to setup, I take the loose leg off the tripod and carry the tripod with the two legs on it in one hand, and the other leg in my other hand. I set the tripod up in the same spot every time so the level is usually pretty close. Then I bring out the eyepiece case and the other case with all the screws and power supply and level. I quickly level the tripod and go back inside and get the gem head and put it on the tripod. I then go in the truck and get the weights and put them on the shaft. Then I go inside and get the scope and put that on the mount. I do a quick polar alignment and I am on my first alignment star within 10 minutes of when I started. Take down is even faster. I make one more trip in the house to get my cameras, computer and autoguider. I keep all those in an Igloo cooler with all the wires all hooked up from the cameras to the autoguider and laptop. I carry the cooler in one hand and a folding table in my other hand. I take the computer and autoguider out of the cooler and set them on the portable table and only have to plug one wire in for power and I am ready to boot the laptop up. Once you have a routine, you can set up pretty fast.
Ralph
