RICHARD COFER
M 17
Started by maurice clark, 08/29/2002 05:06PM
Posted 08/29/2002 05:06PM Opening Post
This image is a combination of 3, 1-minure exposures taken with an 8" f/10 LX200 and an ST-8E.
Enjoy.
Maurice
maurice clark's attachment for post 1430
Posted 08/30/2002 01:01AM #1
Hi Maurice-
Too bad a sattelite went through your fov.
-Jake
Posted 09/16/2002 06:37PM #2
Nice image! I note taht you have three images. Have you tried using a median combine? That should eliminate or at least greatly reduce the visibility of that satellite track.
Also, your white point looks to me to be a little bit too low. Or perhaps you added these images? You may have saturated if you added. An average is just as good as a sum, but prevents white saturation. If you did average, then perhaps the 1-minute exposures are a bit too long - more exposures of a shorter duration would give you more detail in the bright areas.
So the cure depends on the methods you used; if you need more informaton on any of these methods, just ask.
Ron Wodaski
author of "The New CCD Astronomy"
http://www.newastro.com
Ron Wodaski
New Astronomy Press
