Hi Tim,
I don't know your setup, but heres some general suggestions:
Use a Cat Cooler or install some fans to help cool down the
mirrors inside the scope. These SCTs are especially prone to
internal thermal problems.
You want to run around F20 to F30. Use a Barlow or PowerMate
to make the image larger on the detector.
Use high frame rate to freeze the image moton. Probably 20 to 30
frames per second is good, unless seeing is stable.
Check the collimation of the system using the camera on a
nearby bright star or even one of Jupiter's moons. You
should be able to see nice uniform donuts on both sides of
focus. You may need to turn-up the camera gain or turn
down the frame rate to see the out-of-focus images.
Use some software to blow-up the screen image for focusing.
Windows XP and Vista usually has something called "magnify"
in the system32 folder.
Expose individual frames to only about 50% of full range
(i.e. like 130 counts out of 255 counts). It very easy to
over-expose and saturate. Keep the exposure time near
maximum for the frame rate (e.g. 50msec for 20fps), but
turn down the gain.
Unless the seeing is really good, you'll want a lot more
than 280 frames. You can expose for about 2 minutes on
Jupiter before you start to get smearing from rotation.
So you can easily get say 20fps x 60 x 2 minutes = 2400 frames.
You can go even longer with some careful processing to
control image smearing.
Here's a shot I got couple weeks back in better-than-average
seeing right here in Maryland. This was a C14 + TV 2.5x PowerMate +
SKYnyx2-1c (color) camera. I also used a wedge prism to take out
the atmospheric dispersion. Exposed at 20 fps. Best 3700
out of 4600 frames. Not Australia, but some nice details anyway.
Cheers, - John B.
