Wizard Nebula
Meade Pictor 216XT, USB To Serial Cable, ect
Started by DirtRat, 08/19/2004 07:56PM
Posted 08/19/2004 07:56PM Opening Post
Hello all. My first post here.
First id like to ask if anyone has PictorView software ver 6.2 that they would be willing to email me. I delleted it from my (old) laptop hoping ver 7.25 would work, but it doesnt. Its a lowly P-120/win95 with a serail port and it works well enough for what i do with it.
Second, i did go and buy a (new) laptop, but it has no serial port, so, i go and buy a Meade USB to serial cable /w software ver 2.0 hoping id be able to use this laptop with the Pictor. But as luck has it, it doesnt work either. Meade doesnt make the 216XT anymore so tech sup couldnt help. It does seem to connect to the ccd, least it says its connected and when i click disconect, i do get the cool down option. The 216 displays PC when connected. All i get when i take a image is a black image and it takes about 15min to download.
It says on Meades webpage that the cable is compatible with Pictor ccd/software. But, its says on the directions that came with the cable, it is NOT compatible with Pictor products. geez
If i can find PictorView 6.2, which works on my old laptop, with a serail port i can use it again.
Thanks in advance for any help.
Craig
Posted 08/20/2004 03:11AM #1
Craig,
Meade has Pictorview 6.45 still available on their website, which is DOS compatible. I also might have an earlier version laying around if needed. I would really suggest trying to update to the latest version possible that your hardware-software can support.
Posted 10/31/2004 05:49AM #2
...Resently purchased a 216XT, had same issue on new laptop, found USB-to-Serial adapt that works fine, product:
Keyspan p/n USA-19HS
avail at CompUSA 39.95 (sku# 309975)
...When using my TouCAM.. to get rough focus i use a 6mm EP
can some1 tell me which EP i can use for the 216XT to get
same..?
TIA
