Neptune rotation movie, white clouds, dark spot
Started by Exosearch, 08/01/2009 06:14AM
Posted 08/01/2009 06:14AM Opening Post
I made this 7 frame animation of Neptune rotating using images from Voyager 2 images that used a methane filter
http://setisociety.org/neptunerotation.GIF
The time span is 5 hours and 11 minutes on Aug. 23rd 1989. The spacecraft moved quite a bit between each frame, so I hand-centered each frame using Adobe and animated it with GIF Construction Set Professional. I processed the original images from TMQ format, and fiddled with the gamma levels using AIP4Win and saved as TIF's. Then after centering in Adobe I saved as low-compression jpgs and then as a GIF movie. The black dots are used by NASA to calibrate image scale and spacecraft motion relative to the planet.
Regard, Jason H.
