Ruben Tommasi
Andromeda Galaxy (M31)
PLATO (12" LX200) f/36
Started by seventhunders, 04/15/2011 11:37PM
Posted 04/15/2011 11:37PM | Edited 04/16/2011 06:37PM Opening Post
Hi all:
It seems like I have not posted here in years. Seeing was good Tuesday evening. This is a first light image with my new scope, well not really new, it is a six year old Meade 12" LX200 GPS/SMT UHTC with Peterson mods. The corrector plate may be off plane a hair and I think the primary mirror is being pinched in its mount, I'll fix both of these small problems next week. The optics are very good and tracking is silk smooth!
This image was captured on April 13th at 1:54UT, using "EP Projection" and a 12.5mm Orion Highlight PL eyepiece that produced a magnification of f/36 or 11,000mm. Plato filled almost the entire 1/4" CCD chip. Philips SPC900NC webcam; 15fps for 1.2 minutes, shutter speed 1/50th. Best 350 out of 1,060 frames stacked in Registax 5, single point process. Microsoft Digital Image for post processing. It's a color image with no attached filters other than a Baader UV/IR cut.
Clear skies, Dan grin
seventhunders's attachment for post 53204
Posted 04/17/2011 12:39PM #1
Nice shot, Dan. smile When I used to do a lot of visual observing, I'd use the number of craters I could see in Plato as an indicator of 'seeing'. Under seeing as good as in your shot, I suspect that you could capture the rille in the Alpine Valley without too much difficulty.
Darian R.
