Philip Imbrogno
Elephant Trunk Nebula
Re: opinions on Vixen GP-DX autoguiding setup??
Started by inbred, 02/24/2003 07:07PM
Posted 02/24/2003 07:07PM Opening Post
Not sure about the the star2000 setup, never used one. If it is designed to work on drives with a standard autoguider port, I would assume it is probably mechanical relays shorting the direction to ground to induce movement. If it is indeed isolated mechanical relays, (like my sbig camera with external relay box), the modification should be fairly simple. I don't know how electronically savy you are, so I'll try to keep it simple. If the buttons on your hand controller are in the same configuration as my cheap chinese version (which I'm 95% sure they are), pushing the button will short the circuit to ground, and move the motor. Open the controller and follow the traces. if all the buttons have a common connection, that should be the ground. the other side will correspond to the button's drive and direction. The button acts as a the 'on/off' switch. Now the goal is to let the camera relays act also as one of these switches. So, basically a standard autoguider cable is set up with 6 wires; wire 1--no connection. wire 2--common ground. wire 3--RA-. wire 4--Dec -. wire 5--Dec +. wire 6--RA +. The goal is to have a 6 line female phone jack on the dd-1 to accept the autoguiding cable (I think it's easier to have a short wire extending from the controller and mount the jack to that, as opposed to flush mounting the jack to the controller). basically, splice a wire to the common point of all buttons (or any good ground point, preferrably closest in the circuit to the buttons), this will correspond to wire 2 in the jack. Then splice a wire on the opposite side of the switch on each dec button, these will correspond to Dec+ and Dec- (which goes to which doesn't matter) (wires 4 and 5). then do the same to the RA buttons, these will go to wire 3 and wire 6. That's pretty much all there is to it. The relays of the camera system will act just like pushing the button. Also in this configuration, the buttons can still be used normally as well without disconnecting any cables. Now you may want to confirm the relays and exact setup of the SX system, like I said I have no direct experience with these cameras.
Posted 02/25/2003 09:43PM #1
well, how long you can autoguide successfuly depends on many things, including the accuracy of your polar alignment, the accuracy of your mount's tracking, focal length, atmospheric conditions, the guider itself, etc. In theory, if your polar alignment is dead on, and your gears and drives are decent (without random wild errors), you should be able to autoguide indefinately. even without PEC, 5-8 minutes is nowhere close to what I would a reliable figure. one of the setups I'm using is a Takahashi fs-78 refractor @ f/5.9 (460mm focal length) with an SBIG st-2000 Camera. This all rides on a standard GP mount, outfitted with cheap chinese drive motors and controller (for an eq-4 mount). I usually shoot 10 minute exposures with it, and have experienced nothing but joy. Admittedly I have tweaked the mount a good bit (regreasing, deburring, etc.), but considering the motors running it, I'm very happy with the performance. I could easily go much longer if I like (but I really don't like taking the risk of airplanes, headlights hitting the scope, cosmic ray hits, the cat bumping into the mount, etc.) As little time as I have to image, I'm a lot more comfortable throwing away a 10 minute exposure than a much longer one if need be. Granted imaging at this relatively tiny focal length is very simple. The mod would work with any camera having mechanical relays (ie an st-4 or st-237, any other sbigs should have the optional relay box). Personally, I'm not a big fan of SX cameras, especially with the star2000 routine; guiding with the star2000 exactly doubles your exposure time over using a seperate autoguider or a camera with a seperate guide chip (such as sbig). There's several other reasons why I'm not fond of them, but they are mostly personal tradeoffs that may not apply to yourself. What intrument(s) do you plan to image on the mount with? If you don't already have it, buy Ron Wodaski's book 'the new ccd astronomy' before buying equipment; it will help you much more than I ever will. Regards.
