Hello Robert,
You sure did some high resoultion imaging here
I believe the formula to calculate your image scale is:
size in microns of the pixels of your imaging device / your focal length in millimeters and the result then multiplied by 206. The result will be ALREADY in arcseconds per pixel
In your case: if you were actually imaging at F50 then your focal length in millimeters would have been 14,000; the pixel size of the LU075 is 7.4 microns. So your image scale is an astonishing 0.1 arcseconds per pixel (7.4/14000*206= 0.108.....).
Ciao Robert and congratulations on the image: considering the resolution it is incredibily smooth and well detailed.
Thanks for posting it.
Luca 8)
Luca 8)
www.amun-ra.org
Solar Imaging Website
