registax
Started by EReed, 07/09/2007 06:31AM
Posted 07/09/2007 06:31AM Opening Post
Hey guys, I was tinkering with Registax tonight and tried processing a video of Jupiter taken with a digital camera, however every time I try to load it into Registax, it says "Failed to start AVI decompression." I tried saving as a different format, and taking a video as a different format with the same results. Anyone run into this problem? Thanks!
Evan
Posted 07/10/2007 06:42AM #1
Evan,
A quick search found the following possible answer:
http://www.astronomy.com/ASY/CS/forums/277349/PrintPost.aspx
"You could uninstall and reinstall Registax and whatever camera software you use to download the AVI to your computer (but that's a big pain in the rear) and/or you could update your codecs (if you're good with computers). Some tell me you could download Virtual Dub. This is a freeware utility that will decompress your AVI and save it. Then you work with it in Registax."
This is the link to VirtualDub:
http://superb-west.dl.sourceforge.net/sourceforge/virtualdub/VirtualDub-1.6.19.zip
Good luck,
Chris
Posted 07/10/2007 01:59PM #2
Hello Evan,
when I had your sort of problems (lumenera cameras' users all had them), I used to run my files through VirtualDub. Load the file in the program and then save it using the "save as old avi" option (if I remember correctly). It will positively work with Registax in the new version.
However, I learned fast that this cannot be common practice, because it is a useless burden. Processing is already a time consuming activity and accepting an unnecessary step is pure masochism.
So my advice is: find a way to avoid using VirtualDub. Which means: find what creates the problem with your avis and Registax and solve it, even if you have to uninstall and re-install all the related software. It sure beats using virtualdub with every file!
Sorry I can't help more than that sad
Ciao
Luca
www.amun-ra.org
Solar Imaging Website
