RGB help
Started by joe B, 09/02/2003 01:30PM
Posted 09/02/2003 01:30PM Opening Post
Need to align RGB planetary image set. I can't figure out how to register them in Paint Shop Pro and IRIS wont save color image. APIWIN4 seems to be on crack when I select color processing.
Any suggestions?
Posted 09/02/2003 06:11PM #1
I've been working on this in Picture Window. The way I found was to use the overlay feature (what it calls composite) and use the subtract operation. Then I move the images around to minimize the difference between the two, and finally set the overlay image to 100% so it completely replaces the 1st (reference) image and save it.
I'm not sure if this is something you can do in your program, and its very manually intensive. I eventually want to make an animation of Mars rotating.
-Joe
