Tonight I downloaded the new Registax 5 and tried it out on a bigger Saturn run (the following image is only 16k)
http://setisociety.org/SATURNMVI_0709R51SL.jpg
That run started off around 1.46 gigs from my last good session Feb. 21; I originally couldn't use that run in Registax 4 because of its size (~1 gig limit) but was able to load it in the newly released Registax 5.
I started off with 1626 frames and ended up with 1466 (by manually removing frames) and didn't re-size it as the detail was a little less on that run, but it seems like the extra frames helped the color a lot (I didn't touch the saturation.)
Post-registax processing done in Roxio Photosuite 5. I have a lot to learn about the new Registax (not that I knew anything about the old one :^) but some of the new features do look interesting.
Criterion RV8, Canon Powershot SX-100 w/10 optical zoom, 26mm Meade Super Plossl, 2x Ultima Barlow.
Regards, Jason H.
Regards, Jason H.
