james carter
North American Nebula NGC7000
SBIG for C-11/Hyperstar and FSQ wide field?
Started by Hacky, 02/05/2004 06:57AM
Posted 02/05/2004 06:57AM Opening Post
Is there an SBIG camera/autoguider that would accomodate CCD imaging with both a wide field refractor and also a SCT/Fastar/Hyperstar?
Thanks.
Posted 02/05/2004 11:31AM #1
The ST10XE... would work. You could use it binned in the SCT, and unbinned for widefield work using a refractor. Actually even the ST7, ST8, ST2000 would work okay.
The problem is with SCT scopes... using faststar or f/3.3 focal reducers. There will not be enough back focus with the focal reducer for color imaging, and the faststar assemble isn't intended for such large obstructions...
The hyperstar from Starizona however is the exception for the C14... if you have a c14 you may be fine.
Finally, SCT's with the 0.63x focal reducer seem to be fine and have no problems.
Hope this helps.
Posted 02/06/2004 05:41PM #2
The ST-5c and ST-237 (Pixcel 255 and 237) will work fine - including color imaging. I have the ST-5C and works fine for a number of scopes. The larger SBIG camera's may be just too big - and use external Filter housings adding inches to the back focus.
Don't discount the MX-5 and 7 also. These - i've heard - work fine.
