Hi!
I purchased a MX5-C second hand and while searching for information on all its capabilities, http://www.starlightccd.com/ had links for all the camera CCD data specs on the sony site. Most of the links no longer work because the CCDs used in the cameras are no longer available.
Looking at Sony's discontinued product line page in some cases gives replacement CCD that are pip-for-pin replacements of the original CCDs. For example: in my case, the MX5-C uses the ICX055BK sensor. The ICX055BK was discontinued 06/30/2001 and replaced with the ICX405AK. I have the pdf data sheets on both and they look identical as far as pinouts/output and signal/voltage level requirements.
The ICX405AK is supposed to have higher sensitivity (+5 dB), lower smear (-20dB) and Higher D range (+3dB) as compared to the ICX055BK.
I should be able to directly replace the CCD.
Thoughts? Are the latest Starlight Xpress cameras being sold using the current Sony chips?
I also posted this message to the Starlight Xpress message board system hope to hear an answer too.
Thanks!
Rich
Thanks!
Rich
