VDB 142 Elephant Trunk HOO
Toucam / Webcam Autoguider Question
Started by Gene, 01/03/2005 02:44AM
Posted 01/03/2005 02:44AM | Edited 01/03/2005 02:49AM Opening Post
I'm a little puzzled and need some help from one of you pro's out there using a Webcam as an autoguider. I have a Philips Toucam on one of those Chinese clone 80mm short tube refractors(400mm focal length) which is going to be used strictly for autoguiding.
I bought this Toucam new in the box and then purchased a Moog screw on adapter (there's no lens on this webcam anymore just the ccd chip).
My question is when I connect my Toucam to this short tube and focus it - it has a very small field of view and appears I'm at a very high magnification like 100X and at the upper end of the magnification of what this scope will take and using it at prime focus (no eyepieces). This very small field of view makes it difficult to find stars / focus and use them for autoguiding. I've spent 20+ minutes just trying to find a star with this thing before giving up. Am I doing something wrong or just not patient enough?
I've seen focal reducers for use on a webcam but didn't think it would be critical when using a short focal length refractor. Am I wrong or missing something here?
Posted 01/03/2005 02:29PM #1
Welcome to astrophotography. Don't feel bad about feeling impatient. Nobody in their right mind is patient enough for astrophotography.
The easiest solution is to use a reticle eyepiece in your Chinese clone to center a star. Remove the eyepiece and insert your camera. Focus the star with your webcam. (Note that the problem may not be that the star is off the chip--but that the chip is not sensitive enough--or exposure not long enough. Try it in the day first to get the technique down on a telephone pole. Then a real bright star at night to start.) Remove the camera and re-insert your eyepiece. Without changing your focuser position, move your eyepiece in an out of the focuser tube until it focuses. Mark this position on the barrel of your eyepiece (or use a "parfocalizing ring"). Now, whenever you first start out, just insert the reticle eyepiece into the focuser to the same position, center and focus the telescope, and you should be on your chip.
Posted 01/03/2005 02:33PM #2
You need to make a parfocal eyepiece. That will make finding and focusing stars a lot easier. Set up your scope in the daytime with the webcam on it pointing at something far away. Adjust the focus until the webcam is in focus. Take out the webcam and put in an eyepiece, but don't touch the focus. Slide the eyepiece in and out of the barrel until it is in perfect focus. Now mark the barrel of the eyepiece with a sharpie or scribe a mark on it. Now you have a parfocal eyepiece. When you set up at night, put the parfocal eyepiece in the scope up to that scribe mark and focus the scope. Center the star in the scope, then take out the eyepiece and put the webcam in. Your star should be in the field of view of the webcam and pretty close to focus.
Ralph
