Iris Nebula
URANUS - 14 hours of rotation w/ white cloud
Started by Exosearch, 08/02/2009 04:07PM
Posted 08/02/2009 04:07PM Opening Post
I made this 13 frame sequence of Uranus rotating with a white cloud using Voyager 2 methane filter images from NASA's Planetary Data System. It's hard to see, but if you look very carefully, you can see the white cloud near the 8 0'clock position, rotating counter-clockwise near the limb
http://setisociety.org/UranusRotationCloud13frames.GIF
The time span is 14 hours and 24 minutes and were shot between Jan. 22-23, 1986. I've read in many books how Uranus was featureless as a new cue-ball during the Voyager flyby; perhaps this is the 1st Voyager/Uranus cloud rotation movie uploaded to the internet?
I converted the original IMQ images to TIF's using AIP4Win and adjusted the gamma levels. Then I hand centered each frame in Adobe (because of considerable spacecraft movement between each frame.) The black dots are used by NASA for determining image scale and spacecraft movement relative to target.
Regards, Jason H.
