Using Extended USB for imaging
Started by crwdjha, 03/11/2004 02:40AM
Posted 03/11/2004 02:40AM Opening Post
I was wondering if anyone in the forum here has used or is using an extended USB system for remote imaging. Systems such as Icron's where USB can be operated thru cat5 cabling using there 2 little USB to cat5 boxes.
I have just started using such a system that uses about 150 feet of cat5 from the office to the observatory. One thing that I've noticed is that as images are downloaded the noise factor in the image increases as each one is sent from the camera to the computer. In other words the images get more of a "snowy" appearance until by the 10th image you can hardly make out the image at all!
I am using just an SBIG STV right now, with no other camera. I'm using it in the E-finder setup.
Comments or suggestions?
Dave H.
