Jay Messeroff
Lunar & Solar Transits
Canon 20D on a 8" SCT
Started by pelaha, 04/07/2005 03:24AM
Posted 04/07/2005 03:24AM Opening Post
Please bear with me - I'm new to this forum. I've been skywatching since I was in grade school in the 1970s but I've been a very casual observer so I don't know much if anything...
I want to hook up my Canon 20D to my old Meade 8" LX-10 S-C telescope. I want to be able to take decent(i.e. doesn't have to be professional quality) pics of the nearby planets, as well as decent pics of galaxies, globular clusters, and nebulas. My priority would be planets > nebulas > galaxies > DSOs. I know that I need a T-ring, and it looks like I need a projection adapter.
My questions: is the cheaper T-ring offered for $17 by Orion good enough? Should I purchase a basic T-adapter also, or is a good projection adapter all I need? What do you guys think about the 1.25" MaxView DSLR projection adapter offered at http://www.scopetronix.com? Could I do what I want to do with the T-ring by Orion and the Scopetronix MaxView DSLR? Is there a better way I should go? Thanks to anyone who can answer some of these questions.
--Pete
Posted 04/11/2005 09:23PM #1
Posted 04/11/2005 11:36PM #2
Well you'll definitely need a T-Ring. This is how the camera is attached to all these adapters and accessories.
For planetary shots you'll need a Eyepiece projection unit, you can also use an 1-1/4 T-Adapter in conjunction with barlows.
For all other DSO's you'll need a SCT T-Adapter to shoot prime focus. I would also suggest for DSO's getting a F6.3 focal reducer and a off-axis guider of some sort (guiding is critical at that focal length).
Hope this helps,
Robert W.
Posted 04/22/2005 01:18PM #3
Peter,
The standard eyepeice projection adapter usually unscrews into parts, one of which is the 1.25 adapter that fits into a focuser on one side, and accepts a t-ring on the other.
However, you probably want to stay away from eyepiece projection itself until you get better at some of the other challenges. It is mainly used for high magnification of small objects, not deep sky.
