Iris Nebula
Canon 50D or T2i
Started by JoeRam, 08/25/2010 05:09PM
Posted 08/25/2010 05:09PM Opening Post
All,
I'm thinking of getting a new DSLR and have 2 in mind; the Canon 50D and the Canon T2i. As for arcsec/pixels go I calculate with my 80mm F6 refractor the 50D @ 2.0, the T2i @ 1.8, and my 300D @ an easy 3.15. With my 130mm F6 refractor it gets even harder: 50D @ 1.24, T2i @ 1.14, 300D @ 1.94.
As I understand it the more dense chips of the 50D and T2i will provide more resolution, but may be at the risk of increased noise, although compared to the 300D it might be an improvement. I like the live-view function and the higher ISO capability, but I am not sure the upgrade will make a significant difference compared to the 300D. Also, I know both cameras have the gapless micro-lenses too.
With all of this said (or typed) my questions are as follows:
It is worth the upgrade from the 300D?
Will I see more noise due to the chip density?
Will the gapless micro-lenses really make a difference?
Although the arcsec/pixels is lower on the 50D and T2i, will it be much harder to image (I have a pretty good GM8)?
If the upgrade is worth it which camera do you recommend?
As for everyday use (birthdays, family, etc) I think either would be fine, but prefer the 50D. Seeing the main reason for upgrading is astro, this carrys more weight.
Any help and insight is greatly appreciated.
Thanks.
Joe
