VDB 142 Elephant Trunk HOO
Dslr and temperature ?
Started by mike h, 12/31/2012 05:43PM
Posted 12/31/2012 05:43PM Opening Post
I am quite new to DSLR astrophotography. Is there a low temperature point where you are reluctant to take you DSLR or computer out for extended time periods. I am curious about damage to the electronics and lcd screens.
I used to live in Alaska and would regularly take my Olympus OM 1 out at -25 F to -35 F to photograph auroras. The problem at those temps was the film becoming brittle and breaking. Especially where the film advance gear sprocket cutouts were located.
I have since relocated to Kentucky where it ocasionaly will go down to 0 F and I don't want to ruin a new DSLR.
Thanks
Mike
Posted 12/31/2012 07:40PM #1
Check your owner's manual for its "operating environment" specs, then figure you can probably operate outside this range at least a little. How much depends largely on the manufacturer's safety factors that are built into these specs (I have no idea what their safety factors are) and partly on your particular circumstances and your particular camera. Also, batteries don't do so well at extreme temperatures, but there are ways around this.
For example, my Olympus E-5, which is fully weather sealed and is designed for harsher service than most DSLRs, has specified "operating environment" temperatures of 32°F-104°F for operation and -4°F-140°F for storage and humidities of 30%-90% for operation and 10%-90% for storage. I have operated this camera in temperatures as low as 25°F and as high as 110°F and humidities as low as 15% and as high as 100% (i.e. fog) and it never skipped a beat. I have also drenched this camera in the spray from several major waterfalls in Yosemite National Park, again without it skipping a beat. My older but similarly spec'd Olympus E-1 endured even more extreme temperatures (20°F-115°F), many more waterfall spray drenchings, and several inch+ per hour rainfall events, also without skipping a beat. Mark Humpage in the UK treats his E-5 even worse than I do (http://www.markhumpage.com/), including leaving it out all night in freezing temperatures.
Other manufacturers also weather seal some of their higher-end cameras and these can probably tolerate simliar treatment. However, most DSLR are not weather sealed and may not otherwise be designed for such extreme temperature and humidities. My son-in-law has operated his Olympus E-520 DSLR (a non-weather sealed entry-level DSLR) in temperatures ranging from 25°F to 105°F, but he bags his camera in dense fog, near waterfalls, and in the rain.
Posted 12/31/2012 08:41PM #2
The thing you want to avoid is condensed moisture or drips from other equipment that could fall on the camera body and seep into seams. Almost all of the bodies sold have a minimum operating temperature of 32F, but I've used mine as low as 5F and the only problem was a brittle cable from the AC adapter. The camera itself worked fine.
Jim McSheehy
