minolta maxxum 5d
Started by oneaudiopro, 08/04/2006 04:38AM
Posted 08/04/2006 04:38AM Opening Post
i recently purchased a maxxum 5d dslr camera and want to mate it to my stellarvue 80mm refractor. anyone have any experience with this camera? what parts am I going to need to make this all work? How do you adjust the amount of zoom? do you mount it to the focuser or the diagnal? I'm new to this and appreciate any help you might be able to offer...................Thanks!
Posted 08/04/2006 02:13PM #1
Go to Anacortes and ask them for the "camera adapter" and "T-ring" that will work with your scope/camera.
They will bill you something like $40 to 60 or so and ship you a "camera adapter" that has a 1.25 or 2 inch front end that fits into your focuser drawtube (remove your diagonal--it is not usually used in astrophotography). The back end of this device has a set of threads that accept a "T-ring." T-rings are made up of a front end that fits those threads (on the back of your "camera adapter") and a back end that matches the front end of your camera. (The back end of the t-ring looks exactly like the back end of one of your lenses. They are made so that any "universal mount" device (like slide copiers, microscope adapters, camera adapters, even lenses--a jillion things come with t-threads) can be mated to a camera and have everything at the proper focal length.)
Put these things together with your camera, and you can take pictures. Your telescope tube will act like a very long telephoto with fixed focal length and aperture (and therefore fixed F ratio).
Of course, there are other things you will need to take GOOD pictures. The cheapest is probably a remote control so you do not have to touch the camera when taking a picture (of course, you could use the "self Timer" to start the exposures--but that is a pain in the....)
The most expensive is a mount capable of smoothly guiding your telescope, and so forth.....In many ways, the mount is more critical than the optical tube.
By the way-- I should advise you as you begin astrophotography......."Abandon all hope all ye who enter here."
