Wizard Nebula
Re: Camera focal length
Started by Alex McConahay, 06/14/2010 10:25PM
Posted 06/14/2010 10:25PM Opening Post
You have to be able to put the chip (near the back of the camera) in the same place the field stop (near the front of the optical elements of the eyepiece).
Do you run out of travel on the way in or on the way out?
If on the way out, there are several ways to fix the problem, including various extenders, and the diagonal.
If on the way in, the problem gets more complex.
Posted 06/15/2010 10:47PM #1
Good, that is the easier problem. Try using the camera with your diagonal.
Another option is to set your camera a little bit out from the tube. (Don't put the camera adapter all the way in.) Be careful with this--you need the grabbing power of as much tube as you can get.
You will still want to investigate a simple extender. This is the best way in the long run.
