If you can focus with an EP and diagonal then get yourself a 2" long 2inch extender. That should give you enough additional backfocus for your camera.
Re: Camera focal length
Started by dconra12, 06/15/2010 01:57AM
Posted 06/15/2010 01:57AM
Opening Post
Posted 06/15/2010 08:57PM
| Edited 06/15/2010 09:08PM
#1
You are trying to get the camera to a point of focus. The focal length of the lens doesn't change. Anpther way to get an approximate length of the extension is to mount the camera to the scope and extend the focuser all the way out. Measure the distance from the center of the lens to the focal plane mark on the camera. By comparing the measured distance to the lens focal length the difference will be the additional extension needed. From the optical center of your lens to the focal plane of the camera needs to be about 30.7 inches when using the camera adaptor.
Funding Member
