Reducing a diagonal
Started by RobertHowe, 06/13/2009 10:10PM
Posted 06/13/2009 10:10PM | Edited 06/13/2009 10:11PM Opening Post
Hi ladies and gents,
Preparing to photograph an eclipse at sea, I am trying several combinations of telescopes and cameras. I have a lovely fast refractor that I would like to use for wide field imaging, but the camera only comes into focus if used straight thru with an extender; a 2 inch diagonal is too long by a very slight amount.
For the sake of stability I will have the mount as low as I can; focusing straight through will be difficult even with a solar filter, as I will likely be dazzled by a chance glance of sunlight. Is there any way to shorten the light path of a 2 inch star diagonal? Does anyone sell a shorter 2 inch diagonal?
Cheers
Robert Howe
RobertHowe's attachment for post 47174
Robert Howe
Wilbraham MA
TeleVue 85 f/7 // Astro-Physics Traveler 105 f/6 // Astro-Physics 130 f/8.35
Coronado 60 DS
"Scopes, Brains and Wisdom--but no Beauty"
Posted 06/13/2009 11:16PM #1
Robert: Diagonals are taller than they could be in order to keep eyepieces and barlows from contacting the mirror. With a camera this is not a problem so you could have a machinist shorten the top section of the diagonal. This would be relatively easy if you could find a diagonal that allowed eyepiece adapter to be unscrewed... This is common with 1.25 inch diagonals but no with 2 inchers.
Just a thought.
Posted 06/15/2009 05:05PM #2
Robert,
I have one of the Baader 2" units, and it does have a shorter light path. After measuring it, it is only about 1/2" less, so I
don't know if that will be enough for your needs.
Tom
Posted 06/15/2009 08:39PM | Edited 06/15/2009 08:45PM #3
You ought to be able to assemble a system that
is 1" to 2" shorter than your current setup using
the Baader T-2 mirror diagonal and T-2 plumbing.
The idea would be to eliminate the 2" coupling
between the diagonal mirror and camera, and just
screw the camera directly (more or less) to the
diagonal.
From the scope to camera, it would go something
like this:
2" male - T male tube (2" nose piece, part T2-16)
http://www.alpineastro.com/eyepiece_adapters/eyepiece_adapters.htm#Nosepieces
Baader T-2 mirror diagonal (part T2-1A)
http://www.alpineastro.com/Star_Diagonals/Star_Diagonals.htm#t2%20maxbright
T-2 male-male tube or inverter (part T2-26)
http://www.alpineastro.com/eyepiece_adapters/eyepiece_adapters.htm#Threaded%20Couplings
or
http://www.scopestuff.com/ss_temm.htm
Possibly might want a T locking ring or jam-nut to set rotation (part T2-35)
T-ring for your camera
Camera
This chart show another way to do it -- note the
SLR camera at the top left.
http://www.alpineastro.com/Reference_Docs/T2-Sys-engl-P.pdf
