By golly, this was from last year, a series of 5 frames that I did not want to process because it needed flats in addition to dark frames. But I've been shut in becuase of the weather, so here it is, showing just a hint of the rich nebulosity around this region. Those with modified Canons will do much better at bringing out the emissions. As you can see, I should be using a flat frame in something like this that is processed to the hilt.
Scope: Tak Sky 90, reducer, Canon 20D. 5x 6min.
Ivan
Ivan
