Ghost of Cassiopeia
A couple for the experts! part 1
Started by maurice clark, 01/14/2004 02:53PM
Posted 01/14/2004 02:53PM Opening Post
Hi everyone.
I have been trying to rework some of my old astrophotos that I scanned recently and am having some problems with uneven field illumination, mainly vignetting. I have tried using Berry's method of subtracting a blurred version of the image, but the result is too dark. I have also tried using gradients as suggested by Jerry Lodriguss, however that does not work because in many of my photos, the background does not drop smoothly from the centre outwards. The centre is slightly darker, then there is a brighter ring covering about 2/3 of the image before the illumination falls off rapidly towards the edge. Also I find that using this method really gives problems for the colour balance.
Below is one of the images I am trying to improve. It is of comet 2001A2 LINEAR which was a wonderful sight during May and June of 2001. In the image, the tail of the comet extends the full width of the field, however the vignetting makes it very difficult to enhance the tail and make it more visible.
If anyone would like to have a go at this image and get rid of the vignetting, I would be very interested in hearing what you did. I am sure many others would also be interested.
I have Photoshop, Paint Shop Pro, CCDSoft, and AIP4Windows to work with and all suggestions are welcome. I am also posting my results with this image so far.
Regards,
Maurice
maurice clark's attachment for post 12269
Posted 01/14/2004 02:54PM #1
Here is my best effort so far.
Maurice
maurice clark's attachment for post 75135
Posted 01/14/2004 03:28PM #2
Hello Maurice,
I think you have a fine image there, but I am heading out of town and can't really put any time in on it. I think you are definitely looking at just using the illuminated circle as your final output format. There really is nothing in the corners to enhance. The very dark blue fringe may be a very difficult area as well. With this type of vignetting and color unevenness, you are looking at multiple layers within Photoshop. I do think a blurring technique probably compromises your comet detail, especially in the tail. To use this technique you really have to be careful as to what area you clone into the tail. Start with one of the antivignetting techniques by Jerry and then work on selective parts of the image with lasso tool selections. If you don't have Jerry's book, I highly recommend it. Use a variation of all of the techniques in his book. He also describes how to minimize posterization. These lasso selections will vary in color correction and brightness correction via curves adjustments. You may have several layers built upon one another to get the final result. I hate to throw another program at you, but Picture Window pro really has a great radial gradiant tool for anti-vignetting. It may not be perfect in this case, but it might give you a starting point. Don't try to control the vignetting with one move, consider it a building process of several layers. Now that Photoshop CS supports 16 bit layers, I am more patient and cautious with my enhancements and willing to take much smaller bites with each incremental adjustment. Best of luck!
Jeff Ball
Posted 01/15/2004 02:43AM #3
Maurice,
Hmm, I disagree with Steve, I think it's
overexposed.
There are concentric circles of
shading difference (visible when the brightness
and contrast are accentuated). I don't know what
that's from.
I did manage to improve it, but most of the stars
and the comet tail are buried in the background.
I didn't get ALL the color and intensity gradients
out, but am convinced it's do-able. I used various
masks in Photoshop, and curves.
Cheers
Todd
TKL's attachment for post 75176
Posted 01/15/2004 07:08AM #4
Hi,
This is what I got in PhotoShop.
What I did are: 1) duplicate it and take median (radius=7). 2) mask out the comet using copy&paste. 3) subtract the smoothed image using apply image in PhohoShop. 4) levels and curves to adjust contrast and color. 5) smooth the noise in Lab mode.
I didn't get concentric things. I think they were generated in some of Todd's masks. In my background subtraction, an exact background model is generated and subtracted. I also need to point out that I just "subtracted the background." I didn't correct the vignetting. A proper correction of vignetting requires dividing the image with a background model (which is not possible in PhotoShop), but not subtracting.
OK. Here is the problems with the image itself. It's very noisy. It appears bright in Maurice's original image. This is perhaps because 1) the exposure time is so long and the density on the film is high, or 2) the density on the film is not that high but Maurice made it bright when or after he scanned it, 3) density on the film is OK and Maurice didn't do much processing. Maurice, could you tell us more about these, including how you took the picture and scanned it? This may help use to understand the source of the noise.
Case 1) can hardly make the image noisy. It's difficult to make an astrophoto that over-exposed. Case 2) is the most common situation for an under-exposed image. If it's Case 3), the noise must come from the scanner. For Case 3), one can scan the image for N times and stack them together. The scanner noise should reduce by factor of square root N.
This is a good example for what Domenic and I were talking about. Vignetting and S/N of an image are the key for enhancing objects that are fainter than the sky. As long as the vignetting is properly handled and the S/N is high enough, it's possible to get something fainter than the sky.
Hope these make sense to everybody.
Cheers,
Wei-Hao
aloha's attachment for post 75185
Wei-Hao Wang
http://www.aoc.nrao.edu/~whwang
