Hi All,
It's been cloudy here... my Coronado H-a filter arrived, so this was not unexpected! To avoid doing any actual work around the house, I've frittered away some time trying to breathe a tad more life into a recent M31 image.
I wanted to try a few other techniques, and started by applying a PhotoShop de-vignetting mask on the processed image stacks (three panels... upper left/center/lower right) before combining them into a single mosaic. This provided a little more overlap area to choose from than from my previous mosaic, giving a slightly more seamless look (less blotchy transitions). The flattened panel then went back to Images Plus for processing and back to Adobe PS for finishing. I was preparng the image for an egroup where the images are limited to a 480x480 display size, so I rotated the image to make better use of the space.
Taken with an 8" f5.9 Mak-Newt and Nikon CP995, direct-coupled to a 31mm T5 Nagler. It is a three panel mosaic, each panel consisting of 5 adaptively added images, each image at ISO800 and 60.1 seconds.
Perhaps not *the* best, but one of my best stabs at it so far (and I actually learned a little bit in the process... go figure)!
Paul
--- http://www.astro-nut.com/ ---
Paul
