focuss??
Started by ibe, 09/22/2004 04:08PM
Posted 09/22/2004 04:08PM Opening Post
i have a reoccuring, though intermittent problem when taking wide-field shots by piggypacking my film SLR (Canon Rebel 2000) with a 28-80mm lens.
often, but not always, my photos show stars not as pin-points but as coloured cirles several millimetres across, often with blurbed edges.
i assumed that this was because i had not focussed to infinity but vigilent checking prior to taking a shot did not solve the problem.
next, i considered that perhaps the focusser was slowly rotating downwards (and away from the infinity position) with gravity and
mount motion during the duration of the shot. so i started using an elastic hair-tie to hold the focusser in the infinity position once the shot was composed.
this 'appears' to hold the lens in position, however, i am still producing photos with blurbed, round circles of light rather than
pinpoints. the cirles are indeed circular so i believe that tracking is accurate enough and not the source of the problem. especially
since other shots taken during the same session will be ok.
i know that a picture says a thousands words but i not currently in a position to access a slide scanner.
i am hoping that the experience of the group may recognise my issue and give me any pointers, other possible points of failure, or a list of tests to perform to solve this problem.
thanks in advance,
ian
Posted 09/22/2004 11:25PM #1
The only thing that comes to mind is if you are not using some sort of dew shield then perhaps the lens dewed over. Hard to tell without a pic. smile
Robert W.
Posted 09/23/2004 01:19PM #2
thanks for the tips. testing infinity in daylight is a good idea, i''ll try this.
i think i need to do a series of test shots at different focal length and apertures and see if i cant find a point that works.
thanks,
ian
Posted 09/24/2004 03:47PM #3
Ian,
If your film is buckling, you may notice that stars are more focused on one side of the image, but are blobs on the other side. I have had this problem with my 35mm on some occassions. The real solution is to keep moisture out of the film chamber, but this seems like a whole lot of hassle to me (Nitrogen purging, etc.).
Best of luck!
Tim Cross
